Leadtek Winfast TV card question -nevermind
erikiksaz
Is the connector right next to the radio and cable connectors a S-VIDEO in connector? It looks like it, but i'm not too sure. The quality of video coming from the psx connected through that little splitter cable they provided is pretty poor, so i might want to get a straight connection, svideo-svideo.
NEVERMIND, i just checked, it's different. 6 pins instead of 4.
I'm pretty sure its the connection for a break-out box, which would have your composite audio and video, along with an input for S-video. It looks like an S-video in, but all the "teeth" don't quite match up. I have the Asus TV 880 which is a new TV tuner card like the Leadtek, and I'm using the breakout box for my Xbox. Check the pictures on newegg to make sure. If you see the break-out box then you're in good shape.
Chiz
Chiz
Hmm, not sure what you're talking about, there is no breakout box on this card...😕
