Leadtek TV card + cable box ?
Bombino
Hello all,
Basically.. I get about 10 channels (not 2-13) w/ the direct feed into the TV card. I would order a box
from the cable company, but then I wont be able to record on the fly, nor use the winfast remote..
which kinda defeats the purpose of this card.
does anyone know of a signal booster or maybe like a piggyback descrambler for analog cable?..
one that just deals with signal and lets you change channels from the TV itself (or tv card in my case)??
thanks for any help.
-Tony
And the tv tuner doesn't pick up all the channels?
Are you setting the input to "Cable television" instead of the "air broadcast" ?
The LeadTek card should act just like a box.
yes sir.. the feed is set to Cable. I get the same amount of channels with
a regular TV if I bypass the cable box and run the coax straight into the set.
thanks for the reply.
-Tony
My digital cable service gives me over 70 channels on analog still (no box required) and then an additional 30+ channels on the digital side.
Another bump for ya
i have a directv system, how hard will be to connect this card up to it? i would like to be able to record sports games while im at work.
