Leadtek Geforce 2 Pro 32 meg
LeStEr
3,412
What speed can i overclock it to without it becoming unstable? Also what would be the best drivers to use with this card? Im getting one of these shipped to me and I just wanted to get some general information about it befor it arrives.
Thanks
BFG10K
22,709
3,002
Well the stock memory speed will probably be 366, so it should do 400 without too much trouble. Don't bother overclocking the core; all it does is make the card hotter but it doesn't boost performance.
Just take it slowly with the overclocking. Go up in small increments and test your system before going higher.
DimZiE
1,093
yes heatsinks on the mem would definitely helps...
coz all geforce cards i've tried seemed to be memory bandwith limited..,so i wouldn't bother o/c ing the core..but memory o/c ing boost performance really well.if u use heatsinks on your memory you could achieve higher speeds w/ better stability (but remember to attach it properly)
LeStEr
3,412
Now, can i overclock to some extent befor i get some heatsinks for the ram?
BFG10K
22,709
3,002
Look, overclocking is pretty much random.
Generally speaking better cooling yields better results but you won't know how well it'll go until you actually try it. Just take it slow and easy.
Dark4ng3l
5,061
Nobody can predict what your card can do in any circumstances you have to try and find out for yourself.
