Leadtek A280 le THD Video out problem
blure007
When I bought the card I installed the leadtek drivers on the cd. I used to have the option under the advance display settings under the Nivida tab to enable the TV-OUT as a second monitor. I would then make the TV-OUT my default monitor and use that to watch my movies then switch it back when I am using the computer.
I just installed the Nvidia 45.23 drivers and I no longer have that option to enable my TV-OUT in the Nvidia tab in the advance display settings. I am running Windows XP. Does anyone know if I need to use the drivers off of leadtek to enable my video out or is there a setting I am missing?
It's more likely the drivers just hid the option. Check under the "nView" settings.
If it's an older card, look into "TVTool" to greatly improve your output as well.
- M4H
