Originally posted by: BmXStuD
Originally posted by: StormRider
What does the cable from the USB ports on your case look like? Is it one big block? Or is it a bunch of separate little connectors?
all little connectors, and ty for the info above. Umm my case connectors say stuff like +5vsb or -5vsv not data -1 ect so im lost. My case is
Chenming ATX-301KB-A-0 Aluminum Mini-Tower Case Black **No Power Supply**
Your case looks a lot like my Antec SLK2600 Solutions Series
ANTEC SOLUTION SERIES Model# SLK2600AMB
It can be confusing when they label the connectors differently. On my case, they label them as 1+D, 1-D, 2+D, 2-D etc.
The key is to know that each USB port needs a Power and Ground connector. These are usually labeled like VCC, Power, +5V, GND or something. Each USB port also needs two data connector -- one is plus and the other is minus.
So, for the 1st USB port, you will want to connect to the following on the Leadtek:
Pin 1 GND (any ground will do)
Pin 2 +5V (this is the power pin)
Pin 4 DATA 0-
Pin 6 DATA 0+
For the 2nd USB port you need to connect to the following on the Leadtek:
Pin 3 GND (any ground will do)
Pin 8 DATA 1-
Pin 10 DATA 1+
The problem with the Leadtek is that it only supplies one +5V pin so I can only connect to one USB port on the front.
If your case connectors have something like +5xxx and -5xxx then it kind of looks like they might be the data pins. Do you also have something like Power, VCC and GND or something?
