Hey,
I am having some problems with the Leadtek 7350KDA. The board really hasn't been nice to me. I have built 3 systems with the ECS 735 board without any real problems. First the board killed the partition table of my hard drive when i was installing windows xp. I know this probably was a windows thing and not the board but anyway it sucked ass and took a lot of my time to get the partition table back in order. After that the internal Lan card wouldn't work, i finally figured this to be a problem with the board and the santa cruz. I am using the latest bios revision 1/08 and the problems are still there. The board is also beign very picky about when it wants to start and when it doesn't. I also have had better results overclocking with the ecs board than the 7350kda. which sucks cause the reason i got the 7350kda was to try out the supposedly better overclocking abilities. the speed gear app doesn't even work in 2000/XP so its options are just the same as the ecs board with cpufsb. Does anyone know if i should increase the voltage alittle or anythign to make the guy stable. If anyone has a santa cruz and the 7350KDa that works please let me know. I like the santa cruz more than i like the 7350KDA so if they are not compatible then the 7350KDA has got to go. The santa cruz was installed in the last PCi slot, maybe that was the problem.
My systems is as follows:
AthlonXP 1600+
512 crucial 2100
2 Maxtor HD 60 and 80 gig
Pioneer DVD 106s
Rioch CD-RW
Enermax 400 watt PS
Geforce 3
Santa Cruz (not currently installed)
Leadtek 7350KDA
Thanks,
Mike
AthlonXP 1600+
512 crucial 2100
Pioneer DVD 106s
Rioch CD-RW
Enermax 400 watt PS
Geforce 3
Leadtek 7350KDA
Thanks,
Mike
