Leadtek 6800 AGP problem
slick2005
44
I installed a Leadtek 6800 and loaded the 7124 drivers, i installed riva tuner, when i unlock the pixel "pipe" or whatever it is i get small grainy particles during 3dmark 2003, when i uncheck it i dont get it, there is about a 500 to 600 increase in my score when this is on, is this an issue with the card or can i solve this using different drivers or what?
blazerazor
1,480
Duh, one or some of you cards pipes are Defective. Try undoing what you did in rivatuner. Leave the vertex shaders on and try again.
I don't think your odds are good at unlocking a 6800, Unless you bought one of the Very First Ones that came out.
Ryland
2,810
13
I get artifacts with my Leadtek 6800NU also if I open the Pixel Pipes...It is just luck of the draw.
Rage187
14,276
4
as stated above; unless the 6800 is older, there is very little chance of a complete unlocking without artifacts..
