Edit5: Some weird stuff probably noted by me(speculation, where as the above is not) and just to iterate on the leading edge-ness of new 12FDX.
Original 12FDX:
Minimum Lg=20nm
84CPP/56Mx/L=20
2018 Slides said 90% done
New 12FDX (LP):
2020 described: "It has a lot in common with our 12nm FinFET process so we are about 60 percent done. We are optimizing the process.”
Went from being finished to being reworked and being in common with the FinFETs. Original 12FDX as indicated above has a 20nm minimum gate length. While 12nm FinFET nodes had 14nm and 16nm channel length.
Of which, SOITEC/Leti was doing 14nm channel lengths with sSOI wafers through 2012-2016. So, 2017+ appears to have implicated 12FDX into becoming a better node via in-development SOITEC/Leti breakthroughs.
Top image is 22FDX, middle image is 18FDS/14FDSOI, bottom image is the beginnings of the new 12FDX node.
Old 12FDX(84CPP/56Mx/min. L=20nm) => 2019-2020 production.
12FDX LP(84CPP/56Mx/min. L=14nm) => Near finished PDK by April 2023-June 2023
12FDX HP(64CPP/56Mx/min. L=14nm) => 0.1V risk production in 2023
The above appears a lot like 22FDX's eventual portfolio:
22FDX ULL(116CPP/80Mx/min. L=28nm) = Launch choice in 2016
22FDX LL(116CPP/80Mx/min. L=20nm) => Eventually appeared in 2018?
22FDX HP(104CPP/80Mx/min. L=20nm) => Launch choice in 2016
Hopefully, this somewhat explains the weirdness of the potential announcement 12FDX, and then "we also have a production products" in the 12FDX(Malta and Dresden) lines. I really want to iterate that there are products on 12FDX apparently being launched next year.
GF Es' CVs:
-12FDX Integration(2020+)
-12FDX Yield-up(2020+)
-12FDX Transfer(2022+) can only be Malta to Dresden
-12FDX Ramp-up(2022+)
-12FDX Award(2022+) <== At least 5 non-AMD-Qualcomm customers committed on the upcoming 12FDX node.
-12FDX+ Exploration <=== 2H2023 positions for a product in 2H2025. // Gate Length of 12nm is mentioned for these.
Also, after two-ish whole years of 12FDX not appearing on the roadmap, August 2022 it is back:
12FDX In-development 2018->2019
12FDX drought, I assume this is because it went back to R&D. 2020->~2022
12FDX is back on the roadmap, August 2022.
Of which, 12FDX April 2023 through June 2023 is the launch of 12FDX.
