LCDs with max resolution > 1280 X 1024
akubi
4,392
greater than that, get 20" or more.
cheapest solutions: dell 2005fpw=>1680x1050 and 2001fpw=>1600x1200.
Garet Jax
6,369
Originally posted by: Czar
19" all have that
Really? I haven't seen any 19s that support that (at least not from their specs). Can you give me an example?
Juice Box
9,615
19" all have that
no 19" LCDs have higher than 1280x1024....so sad :( I LOVE my 1600x1200 CRT 19"
Czar
19" all have that
ahh you meant higher, then you have go with 20" and bigger screens
BillyBobJoel71
2,610
never get a 19 inch monitor lcd - the quality is very low since you have to expand a 17 inch native 1280x1024 and make the pixels bigger and grainier. 17 0r 20 inch. but the 20+ inches are the ones that have 1600x1200 and above.
RossMAN
Grand Nagus
Feb 24, 2000
78,868
368
19" all have that
Correct if you want higher than 1280x1024 you'll need to upgrade to a 20" LCD which does 1600x1200 or 20" widescreen at 1680x1050.
GoingUp
16,720
seeing as how 17"s are 1280x1024, there really is no excuse for 19"s only supporting 1280x1024....
at the least 19"s really should be at 1440x1080
eLiu
6,407
Do you folks not understand what > means? ;)
But yeah you have to go to a screen >19" for this to work...I don't know why they don't do higher resolution on smaller panels.
NiKeFiDO
3,901
19" all have that
what? ALL 17 and 19" LCDs have max resolution 1280x1024. ALL OF THEM.
edit: nm, alreadhy been answered
sharkeeper
10,886
15.4" here at 1920x1200 native.
Looks great to my nearsighted peepers too!
It's got a built in security feature. If someone wants to see what's on the screen they have to get so close I would obviously know they are trying to see it! :p
yukichigai
6,404
There's a reason I still lug around my 60lbs+ 21" CRT: I like it when my maximum resolution is 1920x1440. Until I can afford a good LCD that can do that resolution or better, I ain't switching.
