I had a few questions about what to look for in a LCD tv to use as a monitor. My goal is to hook up 22 or < LCD monitor, to be used as secondary, and 32 or < LCD tv to be used as primary. Xbox 360, wii, computer, Cable box, and dvd player will be needed to be hooked up all at once. What dpi should i be looking for? i heard 720 is better than 1080 for games to prevent some ghosting issues, how about Resolution recommended 1366 x 768 or 1920 x 1080 ? Response Time? Aspect Ratio? Im so lost
Cost is not a huge issue but hoping to spend no more than 1000 ish. I would prefer 400-600 range, but id like to have something that will last quiet a while.
Aside from basic net surfing i also do some media encoding, editing and video capture,
Current GFX card is Nvidia 260 will more than likely SLI when i purchase my LCD, (Would have to wont i?)
Also what other things should i look at? i currently run 4gigs ram but was looking to upgrade that as well.
Any help you guys can offer would be much appreciated. I was last here when i purchased my last system and all the help that was provided was amazing very pleased with the input and the adjustments i made at your suggestions
