LCD question about refresh mhz
DoC91383
94
Ok, i've read the how to on picking an lcd provided by anandtech and i still have a few questions. With CRT's i know the refresh rate is truely limiting to the fps, lets say if you have 80khz refresh rate on CRT that means you are only really seeing 80fps. Every lcd i've seen doesn't have 100khz refesh rate, and i'm just wondering if that means i won't truely be seeing 100fps on it if i purchase one with 83khz. http://www.newegg.com/Product/Product.asp?Item=N82E16824001064
that's what im thinking about purchasing for gaming.
Crescent13
4,793
Good monitor! You should have 60hz (not khz) refresh rate on an LCD. 75hz at max. I know, it will limit FPS, but it's the only way. The highest refresh rate for LCD's it 75hz right now. Response time is more important than refresh rate. 4ms is VERY good.
EDIT: that 81khz vertical refresh rate doesn't have to do with overall refresh rate, it is still 60hz.
ixelion
984
You are only limited by your refresh rate if you choose to sync the games frame rate to the refresh rate, otherwise your FPS is unlimited. However if your FPS and your refresh rate are not in sync you are gonna get a lot of screan tearing so you are limited in that respect anyway.
DoC91383
94
that kind of sucks, i spend 9 hours a day playing too, so i'd probably notice only having 60 fps. Ohwel it might still be worth it for lans, not having to pick up a crt is probablya nice thing.
Codewiz
5,758
If you machine truly stays over 60FPS all the time, your eyes can't tell the difference between 80FPS and 60FPS.
sourceninja
8,805
65
LCD's also draw the screen different. So you no longer see scan lines. So I highly doubt you will see it. I know I was worryed about it and I've never noticed. I love my 2001fp
Shagga
4,421
This is true. I read somewhere that the LCD refresh rate is not directly linked to the "frames per second" your graphics card is capable of. It doesn't work like CRT as sourceninja says. ;)
Sentinel
3,714
I have a Hyundai L70S running 1280x1024 @ 70 Hertz, 8ms response time, works beautifully.
pcgeek11
22,418
5,019
Check this out: http://www.100fps.com/how_many_frames_can_humans_see.htm Lots more people need to read this also!
pcgeek11
DoC91383
94
It's not about seeing the fps, it's about feeling them. After you spend 7 years of your life playing video games you can feel the slightest frame drop even if it's over 60 in your mouse.
pcgeek11
22,418
5,019
BOLOGNA YOU CAN'T FEEL A FRAME RATE!
pcgeek11
chrisrod01
Banned
Apr 16, 2005
681
What have you been smokeing man lol.You can see if frame drop cause it will act like the matrix slllloooowwww dddoooowwwnnn .. ..
corkyg
Elite Member | Peripherals
27,370
240
So does that mean i will only be seeing 60 fps ?
No - LCDs do not have refresh rates - they are staring pixels. The thing that counts for gaming is the response time. That means how long it takes for a pixel to light up.
For gaming you want at least 12 ms or faster. Otherwise, mouse movements, etc. leave ghost trails.
