OnEMoReTrY
Title says it all.
Originally posted by: RussianSensation
However, for movies and general office work an LCD will be better. It can support wide screen, doesn't take a lot of room and it reduces eye strain.
Originally posted by: guidryp
No backlight bleed: CRT's tend to be quite consistent.
Actually, they have a better black level at calibrated settings, but uniformity is no worse or no better according to this article: http://www.behardware.com/articles/613-5/the-last-crt-survey.html
Originally posted by: CP5670
I think the CRTs they got in that article all more or less suck. (two are shadow masks, and the third is an obviously defective Diamondtron with the same problems I have seen on many duds)
Originally posted by: Reagle
I like my home computer monitor to be used in darkness. I kind of like CRTs. But I have never had a flat panel, except one that killed my eyes.
I sorta am leaning to buying a high end crt and run it at a very high refresh rate. Maybe I am crazy but I think a high end CRT running 200 hz refresh rate is the way to go....
Everyone else probably disagrees with me. But whats the problem with a properly adjusted high end CRT ??????
I could be wrong but I don't think that affects uniformity. The phosphors used are more or less all the same (P22).
Originally posted by: JRW
When it comes to office usage or if you're mainly working with Text I would choose LCD over CRT, However when it comes to gaming and picture quality when watching movies nothing beats a high end CRT.
