LCD Monitor Problem
MAEST
I have a 17in Cornea MP704 LCD monitor and a big problem. What happens is at seemingly random time intervals, the screen will begin to flash off and on, usually speeding up with time. The green LED also flashes. As you can guess, this is a big problem especially when doing on flag run in UT2004. I have found a way to fix it for a time being by, when the flashing starts, unplugging then replugging in the power cord in the back. This usually leads to normal operation for another hour or two. However, I would really like a better perhaps permanent solution. I realise I may have to RMA it but at the earliest that will be in the summer and if possible, I don't want to be without a monitor for too long.
It sounds to me like it might have a problem with it's PSU and this is why it's "fixed" by cycling the power. I would RMA it ASAP and don't wait because RMA periods can run out.
-Por
You are not alone. I have similar problem with my unit, but probably not frequently happened as you had. What is your final solution?
