LCD monitor problem.
Telinar
123
Hi, I recently got a new LCD monitor. Recently, certain colors on the screen don't seem to display properly and flash green, red, or some other color. These incorrect flashing colors move with the graphic as i move them around on the monitor. aI tried installing new drivers, but that didn't fix the problem. Anyone have any ideas? Thanks
Viper96720
4,390
It's not dead pixels? Can you use DVI or analog? Try using the other one of whatever your using if possible.
Mem
21,476
13
Did you get any CD software that has colour adjustment with your LCD? I just received my Samsung 191T today and used the colour software(called natural colour) on the CD to get the colours right.
egale
848
If the flashing pixels move along with the object, my guess is that it is not your monitor that is at fault. The more likely culprit is your video card or video drivers. I suppose it could be a bad connection too but I doubt it. It might even be a corrupted windows installation but I doubt that too. Also check to make sure the fan on the video card is working and the fans in your case are too.
It would be easy enough to check if it is the monitor by trying a different monitor on your system. But, if the problem moves with the image, it is not the monitor.
