LCD monitor help!
camryboy
93
I have a 15" Gateway LCD monitor.
Model No. FPD 1500
Power: DC 24V 1.2A
I'm missing a power cable for this monitor. I have called gateway and they cannot get me the power cable.
I have also tried with radioshack with no luck
does anyone know where i can get this power cable?
camryboy
93
i called gateway for about 7 times. all they did was transfering from department to department and ending up hepless
MacaroneePenguin
321
Where did you get the computer from (online, retailer)? I'm assuming you got it pretty recently since you have a LCD monitor.
Rucsac
38
Hi Camryboy, try this - in the UK we have a Council run department called "Trading Standards". It is the link between the seller and the person who has entered into a contract by purchasing goods, which =you/your friend.
In the UK, if new goods fail to work, they are deemed "not fit for purpose", they can be sent back unless the problem is sorted. In the UK, I would be saying to you ring "Gateway" and speak to the Customer Services Manager, tell him you are recording the converstation and after seeking advice you are giving him 7days to sort out your problem once and for all. Also sending a letter, recorded delivery to the same effect. Apparently in the UK you have to give them time to rectify the issue.
By law, we the "purchaser" are covered against things like this. In the States I obviously have no idea of what the department would be called. Also -was the purchase made by credit card? If so, get in touch with them also a.s.a.p. They may be able to claim the money back under Gateways neglect.
Simply put, they cannot refuse to sort this problem out, if you need to send the whole thing back..
Hope this helps..
