[SOLVED]. Unfortunately, I do not have a lot of experience with the effects of VGA cabling. But that was the issue in this case. Changing the VGA cable setup, removed the lines, and the lines in the screenshots. Must be something about thin vertical lines that the VGA cable did not like, as when I zoomed in previously, the "astigmatism" would go away. I only got to it now because I had an emergency and had to leave my home for a bit.
Actually, the cabling from my new computer when to a VGA switch, and then a 2nd cable went from the switch to the monitor. The switch was there so that I could easily change inputs to a monitor between the computer and an Xbox. The switch worked fine, with the same cables in the same arrangement with a Win98 computer, a laptop output, through two different monitors.
That said, is the signal just weak from the HD4830 card?
=== ORIGINAL POST ======
http://home.comcast.net/~bjgollatz/default.htm
The above link goes to a 550kb screen shot of my monitor. I outlined in green, these "rippled" vertical lines that go in the direction to the right of some objects. That can appear in different colors, I do not see it at all in black, or white (or its effect is reduced).
Should this monitor be returned? It is a AOC 2019Vwal
I thought this was a result of a cheap integrated graphics card and dismissed it. I have installed a Radeon 4830 card with new graphics and it is the same. It occurs at the native resolution also. This screen shot is not at the native resolution, but the next highest.
