lcd monitor act as tv?
Nerva
2,784
is it possible to somehow get an lcd monitor hooked up to digital cable? it's currently connected to my laptop.
i thought of this because i think it may have been done by someone...
E equals MC2
Banned
Apr 16, 2006
2,676
This is pretty common, no?
I think one of the vid cards come with an outlet or something.. or a TV tuner hooks up directly to the coax cable to the wall.
Nerva
2,784
i dunno. i am just tossing the idea around. i do not have a desktop pc, so i am not exactly sure how a tv tuner would help.
rbV5
12,632
Depends on if the LCD monitor has the input connections supported by the digital cable tuner. LCD TV's have a number of different inputs, however LCD monitors sometimes have very limited inputs making them unsuitable for TV use without a PC to drive them.
*What kind of inputs does your LCD support?
*What kind of ouputs does your digital cable box support?
mugs
48,920
46
Yeah, that's kind of important information.
And are we talking about HD or SD?
If the cable box only has RCA outputs and the monitor only has VGA/DVI inputs, you could use something like this:
http://www.newegg.com/Product/...tandalone%2btv%2btuner
I know nothing about that model, but I have one made by Kworld that I used to use before I got an LCD HDTV, and I thought it worked pretty well.
1sikbITCH
4,194
574
As a temporary setup, I have a Dell 2001FP acting as a tv right now. It has RCA inputs that are fed from the Directv box. I have external speakers also plugged in to the Directv box. Only problem is I have to get up to adjust the volume.
Edit - most LCD monitors won't have the RCA inputs and you'll have to do some converting as was previously stated.
BHeemsoth
2,738
Many cable boxes have a DVI output which could be used.
Alternatively you could get a HDMI-DVI converter cable and use the HDMI output which should be on the box, provided it is relatively new.
Nerva
2,784
hmmm great suggestions, i would have to check once i move in. thanks guys!
homercles337
6,340
I watch TV on my 22" Gateway all the time. Yes, it will accept many inputs, but im using Hauppage. As mugs said, depends on the LCD.
Ruptga
10,246
207
TV tuner basically makes your PC into a TiVo, then just set it so the external LCD gets the TV signal. You should even be able to watch TV and use your computer at the same time (a remote would make this easiest, and I'm not entirely sure how easy it is in practicality, but I know it's do-able)
rbV5
12,632
Its not quite that simple with digital cable. Since PC TV Tuners basically don't tune digital cable, it requires a somewhat clunky IR Blaster setup in order to change channels on your digital cable box so that you can schedule recordings on different channels...which is the basis for TIVO-like functionality.
Cable-card PC tuners have the "potential" to "TIVO" digital cable, however the only cable-card PC tuner I am aware of is not available to the public and must be purchased in a pre-configured system.
postmortemIA
7,721
40
If it has component input, then it is easy as 1.2.3
however, only 24" have those, and few others.
Nebor
29,582
12
There are several PC TV tuners that can tune Free QAM digital cable. Different cable companies put different amounts of content on their digital cable unencrypted. My FusionHDTV5 is able to pick up:
NBC HD
FOX HD
ABC HD
CBS HD
Discovery HD
TNT HD
PBS HD
UPN HD
CW HD
CSPAN HD
A ton of music channels
And a bunch of standard definition porn (go figure :confused: )
I'm switching to an HDhomerun for my digital cable\PC tuning needs, so hopefully it's more stable than the FusionHDTV5.
rbV5
12,632
NBC HD
FOX HD
ABC HD
CBS HD
Discovery HD
TNT HD
PBS HD
UPN HD
CW HD
CSPAN HD
Realistically, QAM support gives you a fraction of the available channels, many times not much more than any ATSC OTA tuner gives you. HDHR does have Windows BDA drivers, which is a step forward, for sure, but its hardly an endevour for anyone but the HTPC crowd.
Nebor
29,582
12
NBC HD
FOX HD
ABC HD
CBS HD
Discovery HD
TNT HD
PBS HD
UPN HD
CW HD
CSPAN HD
Good luck getting Discovery HD and TNT HD over the air. Better have one hell of an antenna. ;)
