LCD issue, Red dots on black images
cyrusfox
I have an Acer Aspire 7720-6569 which has a 17" screen at 1440x900, I have had this laptop for nearly 3 years.
This problem appeared 2 days ago
This is what shows up on the screen
This is how it should look
I tried to take a close up shot as well, but the camera does very poorly at macro and the flash doesn't help either.
So I can alleviate the problem if I tilt the screen a little towards me, problem is viewability suffers and I need to slouch to use it. I have already troubleshooted it a little. It outputs fine to an external monitor. This laptop has Intel Integrated X3100 graphics. As it has to do with the angle of the screen, I am thinking this is a lcd hardware issue, maybe the ribbon connector that hooks into the screen has a short or isn't connected all the way, hence when I open the laptop all the way extended, it stretches the cord and either loses connection or something else that causes it to distort blacks with red. Blue also has red dots, I used this color print page to test.
Anyone dealt with this before? I am about to rip apart the machine, I have the Service PDF manual for it. Everything else works perfectly on the machine.
If I have to replace, maybe I can upgrade the resolution to WUXGA(1920x1200), but they seem to be going for $50-60 more than the resolution I got. Well I am about to take this laptop apart and see if I can't discover anything, Hopefully I don't exacerbate the problem. Please send any wisdom on this issue if you have any thanks.
It looks like an inverter or ribbon cable issue to me.
Yup. It's relatively common on laptops after a certain time period. Usually something else breaks before the ribbon though so you don't hear a lot of display complains. Anyway you should google your laptop name + display repair or ribbon repair... something of that nature. Usually you'll find a good thread or two where people post how difficult/easy it was to fix. I had an HP lappy do something simlar where the display cut off entirely but I could twist/move the screen and it'd come back. In my case it was quite a PITA to fix so I just got another laptop.
