Hello,
I don't post that often, and i've been reading a lot of posts on here, but I still need some help deciding. I'm interested in getting a LCD to replace this borrow crt monitor of mine, and i've been looking at a few models. I do a lot of web surfing, I do a lot of gaming, and I do watch anime/dvds on my computer. The main two models i've been thinking about are the Dell 2005fpw or the Hyundai ImageQuest L90D+. I remember the CES report from Tom's Hardware of a new LCD coming out from LG Electronics that featured their fEngine technology which enhances how the picture looked, and thought it was quite intriguiing so I would consider one of those as well. I do realize that the LG is a 12ms compared to the L90d+'s 8ms, and the dell being a i'm not quite sure ms. Any thoughts to help my decision? Widescreen sounds like it'd be nice, and I do know that some tweaking and what not is required to get some games to work in widescreen, which i'm fine with doing.
Links:
ImageQuest L90D+
LG Electronics L1980U
Tom's Hardware CES Report on the LG
Dell 2005fpw (Like it needs a link!)
Specs:
ImageQuest L90D+
Specifications:
Panel Type: A-Si TFT Active Matrix
Native Resolution: SXGA (1280 x 1024)
Pixel Pitch: 0.294 mm
Brightness: 300 cd/m2
Contrast Ratio: 700:1
Response Time: 8ms
View Angle: 150° / 135° (Horizontal / Vertical)
Input Connectors: 15-pin D-sub, DVI-D, Audio in
Features: Built-in 2x 2w speakers & Headphone out; Adjustable Pivot & Tilt/Height Stand
Dimensions & Weight: 16.3" x 17.1 x 7.9" (WxHxD), 12.3 lbs
Manufacturer's Warranty / Phone No.: 3-year warranty / 800-568-0060
Specifications:
Panel Type: TFT Active Matrix LCD
Native Resolution: SXGA 1280 x 1024
Brightness: 250 cd/m2
Contrast Ratio: 500:1
Response Time: 12 ms
View Angle: 160°/ 160° (H / V)
Input Connectors: 15 Pin-D sub / DVI-D
Features: AutoPivot, AutoMirror function Flatron f Engine, OSD Lock, Auto Adjustment, Gamma Control, forteManager
Dimensions & Weight: 16.6" x 16.1" x 10.2" (W x H x D) /11.9 lbs
Manufacturer's Warranty / Phone No.: 3 years QuickSwap Replacement Program / 800-243-0000
Thank You,
vpr
Links:
ImageQuest L90D+
Specs:
ImageQuest L90D+
Specifications:
Response Time: 8ms
Specifications:
Thank You,
vpr
