LCD Front panel COnsistent beep
Research
320
Hi,
I got a case from Fry's last week which has a front panel blue LCD display showing time of use, and temprature. The temprture is monitored by 3 wires whose sensors are stuck to HD, VGA and CPU areas with a thermal tape.
Now this case starts beeping continuously as the computer is switched on. Sometimes, pressing random buttons on the LCD (it has C/F, reset, set etc. buttons) helps stop the beeping .. and sometimes it doesn't. There is no manual with the case.
Can anybody please help? Any suggestions?
Thanks!
Shown on lower third column
CrispyFried
1,122
You need to set the alarm temps. See if there is a recessed button you press to set the alarm temps. Then play with the other buttons. Its different for all the different types of displays, so cant really be of more help.
Tiamat
14,068
In my haste, I ripped off the tiny little speaker :eek:
Definatly solved the alarm problem :p
Research
320
Thank you so much for your replies. The case seems to be some RAIDMAX 450Watt ..
I found a little chit that came with the case but all it says is that I should press the reset button .. this does not help .. If I remove the power to LCD screen on the case .. the beep is gone .. but then I lose my cool blue LCD display.
Well, detaching the speaker is the last resort .. (though it is a bit tricky to find that internally wired wire)... Any other suggestions to take care of this issue?
Thanks!
