I just got my Viewsonic VX2025wm and hooked it up with the supplied DVI cable. Well, I got a "no signal" message on the monitor. So I hooked up a VGA cable and it worked fine.
I then tried a different DVI cable with no luck, so I thought maybe my VC DVI port is bad (never used the DVI before). I then found the DVI-VGA adapter that came with my VC and connected the VGA cord thru the adapter and the monitor worked fine.
Does this mean that the DVI port on the LCD is bad, or is there something else I need to try? I really hate to have to RMA this thing, but I don't see how it can be anything else.
