LCD and Tv Tuner
Pezmc
I currently own a 'phat' dell crt 20" monitor that takes up to 1280x1024, however I think this is a waste of my PNY Ge force 6 Nvidia 256mb Graphics Card.
I am looking for advice,
I need a LCD monitor preferably 22" WIDE that takes up to 1650x1050 (I think that's the resolution). Preferably I would like the monitor to have a dvi input as well as a vga, but a vga alone is fine.
As well as this (I'm a greedy ah heck 🙂) I am looking for a Tv Tuning Pci card for my pc with:
DVB support, Support for use of ariel on roof instead of a little crappy one that comes with it, tv recording + pausing features, and composite input (For ma WII).
I have saved up a budget of £250 although maybe able to stretch to more, what should I get?
Any advice/links highly appreciated and if you save me a lot and provide lots of advice a £5 pay pal reward maybe in order
That is a very tight budget,I would suggest you go to OcUK and look at the Hauppauge WinTV HVR-1100 Freeview TV Tuner for 50 quid link, and something like the Belinea 2225S1W 22" LCD for £211 ,do note it only has VGA input.
All the 22" LCDs are TN anyway so choose what one you like feature and price wise.
Btw resolution you mean is 1680x1050.
Also the Leadtek Winfast DTV2000H Hybrid Digital & Anologue TV Tuner Card is worth a look at £41,has composite input connection.
Leadtek DTV 2000H TV tuner homepage. .
