- May 23, 2001
- 3,417
- 0
- 0
I'm definitely looking into getting a 17" LCD (with digital input) monitor pretty soon. I've been reading up and looking around, and it looks like the specs and reviews of the Samsung 171P are pretty stellar. I've called a reseller or two around me, and they are all saying the 171P is gorgeous.
One of the resellers I called says that the 782LE by LG is also very nice (but obviously not comparable to the 171P)
There's a huge price difference though... Like 400 bucks (Canadian) difference between the 2. $1350 vs $980. The guy I talked to said he personally wouldn't spend the dough on the 171P unless he was very picky. But I was planning on using it for a lot of gaming, and I think the 171P's specs would be pretty good at reducing ghosting better then the LG.
A friend said to hold off on buying one for a month, as the prices have dropped in Taiwan, and another LCD manufacturing company is supposed to be starting up soon. But the reseller I talked to stated the prices have dropped already a bit, but only on his larger monitors (some dropped 200-300 bucks on the 19" models) and the 15" LCDs may be affected... I don't think a 18 or 19 inch would be totally necessary for me though. Most likely overkill. And I don't want to get a 15" and be stuck at 1024x768. I'm not a resolution ho, but I like a little higher then that.
I'd really appreciate some input/opinions.
Thanks.
Thanks.
