Layout of "Forum Issues" home screen is cumbersome.
Gen Stonewall
629
This is unique to forum issues: I have to scroll towards the right to be able to see the "Last Post" column, whereas all the other forums' home screens' columns fit onto the monitor all at once. Is this a fixable condition? (It appears that the Forum Issues "greeting" is not aligned properly.)
Hossenfeffer
7,462
It's because of the "greeting":
<< Post issues regarding the forums here, due to the traffic volume of this forum, you are not guaranteed a response.
Please do not repeat questions or bump threads.
When first added, the greeting was a single line and had the same effect on formatting now, except to a greater extent. My short term fix would be to leave out "Post issues regarding the forums here".
Azraele
16,524
29
What's your screen resoultion set at? My screen does not have this problem since it's set at 1024X768.
Gen Stonewall
629
I'm using a 15" monitor, so I don't really want to go above 800x600. (Besides, it seems like this problem can be fixed with just a little alteration of the "greeting.")
Azraele
16,524
29
My monitor is a 15" as well. You might want to try it at that setting just to see. If the text size seems too small, you can adjust it under "View-->Text Size" if you're using IE. If you decide not to go that route, you haven't got much choice other than to just grit your teeth and deal with it until something is done about it.
Gen Stonewall
629
The column layout is improved w/ 1024x768 res., but the low refresh rate capabilities of my monitor hurt my eyes. I shall leave everything as it is and hope that something is done to realign the greeting.
