I knew a guy who swore by vinegar to soak carbs with. He said it would break down the varnish without ruining the plastic or rubber.
I usually strip them down and clean them with carb cleaner and a stiff brush and use a fine wire to clean the passages. Be careful if you use compressed air to blow it out as you can blow out seats.
