Lawn mower with no fuel filter
Status
Not open for further replies.
steppinthrax
3,990
I have a Troy Bilt 6.5 HP 21" lawnmower. I was winterizing it this year and noticed I couldn't find the fuel filter. I contacted Troy Bilt. They indicated that this engine dosen't require a fuel filter. I took the caberator and float apart and noticed it was very clean. I'm kind of curious, is this a new thing with small engines. What happens if a piece of leaf or dirt goes down the fuel tank.
Kaervak
8,460
My 20+ year old Craftsman mower doesn't have a fuel filter either. I'm sure you could add one it if you wanted, but I wouldn't be too worried about it. I did have issues with starting the mower last year because of junk in the carb, but it was easily fixed by taking out the jet and cleaning it, cleaning the bowl, and replacing the fuel line that was on there with the proper stuff. At some point my dad replaced the fuel line with regular rubber hose that wasn't designed to handle gas. The gas essentially ate the fuel line and dumped junk in the carb. As far as leaves and whatnot, unless you're running without an air filter it shouldn't be an issue.
Greenman
22,406
6,527
How much fuel goes through the system? I'd guess less than ten gallons a year. There isn't going to be much dirt to filter out.
iGas
6,240
My 10+ year old Craftsman mower doesn't have a fuel filter as well and still is going strong. Still startup every time on 1 pull on the original carb.
May 13, 2009
12,333
612
I got a Honda push mower I've been using for close to 8 years now without an air filter. It was bought in the winter time as is floor model and they couldnt find the air filter. Changed the oil twice in 8 years. Still runs strong.
slag
10,473
I hate small engines without fuel filters. I put inline filters on most of my push mowers as well as my old MF8 riding mower. Gives me peace of mind that nothing will get into the carb.
Status
