latop and ac power question
Mo0o
24,227
the SFF forums is kinda empty right now so i figger i try here.
a friend of mine said u should remove the battery from a laptop when you're on ac power for extended periods of time. is that true? doesn't sound possible thoug, what happens if u trip the ac cord?
Eli
Super Moderator | Elite Member
8
Sure it's possible, but it would indeed die if you knocked the power cable out.
I don't see why it would matter though. Besides, doesen't the battery charge while your on AC power?
ThisIsMatt
Banned
Aug 4, 2000
11,820
I just leave mine in...like you mention, if the power cord comes out it will die...
On the other hand, if you're using it as a desktop replacement you might as well pull out the battery so the charging circuit isn't wasting power and generating extra heat...
Heisenberg
10,621
Some people think that if you leave the battery in while it's charged eventually it will get damaged because the charging circuit gets 'confused' as to whether it's really charged or not. I'm not sure how true this is. I take mine out to save weight and to minimize the charge/discharge cycles the battery goes through.
gwlam12
6,946
yea im not sure about this either. wont it mess up the battery since you're basically recharging it (while using ac power) when its not discharged yet?
isekii
28,578
Once it hits 100% I believe the battery just goes through conditioning and runs off the adapter.
It doesn't get hot at all.
IamElectro
1,470
I would agree after the battery is charged most chargers shut down internally as not to damage the battery cells..
isekii
28,578
I think you'll damage the battery if you completely discharge it.
I could be wrong.
If leaving in the battery will harm it's lifespan, wouldn't there be some type of warning ? Either via manufacturer or even an computer type article?
gwlam12
6,946
I could be wrong.
ah...can someone please elaborate more on battery and how it can be harmed? i personally alays thought you had to discharge it before recharging it to extend the life of hte battery
gwlam12
6,946
oh another question, what would happen if your battery was at 80% and you were using ac power. then ur battery would start charging right? so what if you then shut off your laptop while your battery is at 90% and not fully charged? would that affect the life of the battery in any way?
ElFenix
102,402
8,574
the battery starts getting trickle charged which is not the best thing for the battery.
ElFenix
102,402
8,574
most notebooks continue to charge the battery if they're still plugged into the wall, even while off. i wouldn't recommend not charging it all the way up
gwlam12
6,946
so do you recommend that i remove the battery when using ac power? otherwise i'd be charging hte battery before its fully discharged
