late nite Matlab help!
Omegachi
okay, i am trying to use the the step() function to find the step response of this equation
syms c l s r;
num = (s*l + (1/(s*c)) + r)
den = r
step(num,den)
for some reason i am getting a error message when i try to solve that:
??? sym c;
Error: Missing operator, comma, or semicolon.
what is going on?
i believe matlab must have the symbolic math toolbox in order for that to work.... if you have a non-student version that it might not have that toolbox. *shrug* that's just what i glean from some pages i found on google...
i get the same error for what it is worth...
first off, did you try "help step"? my matlab is a little rusty, but go ahead and create a transfer function and then use the step function. that might work.
