Originally posted by: hjo3
Actually, light can bend around corners; it's called diffraction. That doesn't necessarily mean that commercial's on the level.
Hence my caveat.Originally posted by: Anubis
yes but its doesnt doit at right angles.... perfectly
theres a discalmer basically says it cant
it only works on a inside corner like this |_ so teh level runs into the other wall and "goes around the corner"
