Hammerhead
I know that these have been around for years, but does anyone know how these are made?
Fricken laser cut paper weights
Originally posted by: Looney
Um i would think your thread title answers it... piece of glass cut by laser?
Piece of glass on some sort of block. Laser above it. Computer is loaded up with the image, and then the laser etches it according to the image.
Originally posted by: alien42
i have always wondered how the laser cuts the glass only in the middle of the block
But how does the laser etch inside of the block without showing traces on the outside of the block?
Originally posted by: Mark R
A laser engraving machine is used to etch the glass.
Essentially, a medium power (30-50 W) pulse laser is focused at a point in (or on) the glass. When the laser fires, the energy is concentrated at the focal point - where the heating is intense enough to fracture the glass, leaving that spot opaque.
The beam is quite wide, so the energy concentration is quite low - except at the focal point. A series of lenses are used to change the parallel laser beam into a wide beam which converges to a fine point, some distance from the outlet.
The laser beam is moved in 3 dimensions by computer control, with a pulse issued where a 'pixel' is to be drawn.
But why isn't the surface of the object effected. It is only inside the object.
Originally posted by: Pliablemoose
The hard part is getting the sharks with lasers mounted on their heads to stay in the lines.
Text
Wide beam, plus multiple beams, as stated if you read what he wrote.
