Large iTunes library, small iPhone capacity, need help.
Sunrise089
Thanks for any and all help.
I am purchasing an 8gig iPhone. Like many of you, my song library is many times this size. I've spent most of my work day browsing apple forums readings about smart playlists and the various workarounds people use to put music on their devices. The general consensus is to create playlists and smart playlists that are smaller in size to the iPhone/iPod and then sync them. Some people also create fancy smart playlist with their least-played or newest music that update themselves as needed. The gist of all of the advice however is to shrink your library down to playlists the size of the device, and therefore exclude most of it. I don't want to do that.
Here is what I'd like to be able to do:
-Place a gig or so of highest rated material on the iPhone - I imagine I just create a smart playlist with 5-star songs and a 1gig limit. Question: what if I have 2 gigs of 5-star songs? Will it rotate the songs out? Randomly?
-Place some of my newest music on the iPhone - I imagine I can create a newest music smart playlist or just create playlists for each new album.
-Fill the rest of the iPhone with a random assortment of all of my other music. I do NOT want to go through my library and exclude certain tracks. Instead I would like to have say 6gigs of music loaded randomly, and then every time I sync have anther six gigs of random music swap in. The goal is to have every track I have (or at least that I've placed in iTunes) have a shot at getting played on the iPhone. Is there any way to make this happen?
Originally posted by: skulkingghost
Just do this:
http://www.simplifymedia.com/
simple as can be! I have used it and it works amazingly. It streams all your music from your home pc.
While I appreciate the quick response, I don't see how this program does what I want to do at all. I'm looking for a way to sync a rotating portion of my entire iTunes library to my iPhone to listen in the car or walking about. A streaming webservice doesn't seem to help much.
Just do this:
I figured you could just put it on random play of your favorite playlists.
Originally posted by: manly
Apple really should implement Autofill for any iPod and not just the shuffle.
Ok, THATS where I remember Apple talking about cycling random music in and out - it's from the shuffle launch. Should I take this post to mean that what I want to do on the iPhone is simply not possible?
I have a variety of different playlists types and it works well (random etc). It takes a little getting used to but my 100GB+ library is doing fine with an 8GB nano. The 16GB iphone I get tomorrow will definitely make things easier though😀
You can have a live updating random filled smart playlist that should change everytime it is synced. I haven't tested it since my iPod is large enough to hold all my music... I suggest playing around with Smart Playlists, they can be quite versatile... i used them for a while when I had my 4GB Nano.
