mentalcrisis00
My Dell laptop has a Dell 1490 wireless card under the hood and it's been having connection problems lately. There are a couple of connection at my college, I look at them in the wireless connections program in windows vista and it tells me Excellent signal for both. They both have WEP security enabled and when I try to connect to it windows says the wireless device didn't answer and that the connectivity source is to low. This is retarded because there are hundreds of other students that connect to these wireless sources with no problems, and windows doesn't even ask me for the password.
The weird thing is that there are 2 low signal sources in both locations, like 1 bar. They aren't security enabled and I can connect to them with no problem. I had a windows error a week ago and it said that the WLAN service failed to start or something.
The laptop connects easily when I hook it up to a LAN cable. I just got the laptop back from DELL also and they said all the hardware was working properly.
Any thoughts? should I try reinstalling the WLAN driver?
