Laptop Wireless Card QUES
chrisrod01
Banned
Apr 16, 2005
681
What the difference between a wireless notebook card
Interface: PCMCIA and
Interface: 32bit CardBus Type II
will they all work on a regular laptop?
And if not to much of a problem can u guys reccomend me one for my sis
Arcanedeath
2,822
All those interphases are the same for the most part, PCMCIA is what cardbus used to be called in the 16bit days (its still some times used today) type 2 is just the hight of the slot used and 32bit cardbus is just the standard (eg like a PCI slot for a normal pc)
CrispyFried
1,122
pcmcia=16 bit
cardbus=32 bit
usually :)
unless its an old notebook that only takes 16 bit pcmcia (<2000) get the cardbus.
Jiggz
4,329
Linksys and DLink is a good place to start looking of wireless PCMCIA or cardbus cards.
Jiggz
4,329
Originally posted by: doinmybestatlast
I've said it before - Senao. There is nothing out there even close. Every other recommendation is by the ignorant.
I'm sorry, I DID NOT KNOW YOU ARE GOD OF NETWORKING! enuf said. Sure Senao is the god of long range wireless but range it's not everything in wireless. In fact, I reduce my router output to 50% to minimize stray signal thus wardriver's from accessing my network.
