Laptop thermal compound replacement - Success!
StrangerGuy
8,443
124
Laptop - 1 year old Acer 4741G i3-380M.
Old TIM: Throttling in Cinebench 11.5, 80+ C
New AS5: No more throttling in Cinebench! Hottest core max temp = 76C
Some thoughts:
1. This laptop requires a FULL disassembly to access the HSF and CPU/GPU as there is no access panel that allows direct access to them. If you are looking for a new laptop I recommend finding one with it, especially if you intend to use it after the warranty period.
2. A service manual is strongly recommended for disassembling.
3. You need to be EXTRA careful if you are doing a full disassembly like me. Lots of small fragile latches/cables to break + tons of different screws to lose. If you are unsure of your self, don't do it. I broke the taping on this laptop HDD bracket, thankfully its just cosmetic.
4. Needless to say you will be voiding your warranty.
CJ8501
74
Yup, did this to my Dell Studio 14z using AS5. It ran so hot just sitting idle I knew I had to take a chance and fix it myself. Disassembled everything, slapped on thermal paste on both the CPU and GPU and its cooler than ever before.
