- Jun 24, 2001
- 24,195
- 857
- 126
This tip is not for those of you with warranties or deep enough pockets for factory repair. This is for those with damaged power jacks and no way to ever find a replacement. This is as close to a replacement jack as you'll ever get!
I get called in to a local computer shop for nearly every laptop repair they encounter (They don't have experience opening the darn things up
). Nearly every time it's because the AC adapter's DC plug has damaged the receptacle on the laptop and they can't get it to reliably charge or power up. Over the first few months, we saw over 20 Compaq Presario 1200 series (Mostly just plain 1200's) laptops with the exact same problem. Every time someone carries one in we shock them by already knowing the problem
Over the same time, we did encounter two Presario 1250's and a few Toshiba's with the same problem, and many more various models since, but now you see why I mentioned the Presarios specifically
I'm sure the majority of laptops are easily damaged in the same way...
When you plug in your laptop, the connector is usually directly soldered onto the motherboard. VERY BAD. Any stress on the plug is directly applied to the solder joints and the contacts within, so it's VERY easy to damage one.
I've seen them with the plastic cracked all around (Into little-bitty unassembleable pieces)
I've seen them with the contacts bent all over and broken (Requiring some seriously small jumper wires)
I've seen them with loose solder joints and damaged traces on the motherboard (Usually requiring a little trace exposure and tinning or alternative solder point hunting)
They almost always have at least two of these problems. Otherwise, the customer would just deal with a "wiggly" power jack that you have to fiddle with to make contact.
My advice DON'T COMPOUND THE PROBLEM! As soon as you notice that the plug is having problems, have someone solder and secure it. But that's not enough! It's bound to be more fragile than ever. It's bound to happen again. You'll never find a replacement connector that solders onto your motherboard just right. You don't want dangerous wires hanging out of the back instead. S do what I suggest the customers do:
Buy a universal AC adapter kit with replaceable tips (Preferably, one with small tips at the very end). Stick it into the repaired jack and GLUE IT GOOD with a strong epoxy. Who cares if you have a protrusion. Trust me, you'll need it. Let it take a beating. Make it A PART of the laptop's housing, so you'd have to crack the laptop to budge it. If it starts to sustain damage, glue it again or replace it. At least something external and replaceable is taking the damage instead.
You could skip the initial repair if you think you can get a good enough connection to maintain with the external plug glued in permanently, but be wary: I've seen charred and fried motherboards with bad trace damage from loose, shorting, sparking, overheating contacts so BE SURE.
As mentioned before, this is as good as a replacement jack you'll ever get.
