Laptop question, need some help (ram)
jimrawr
888
Ok I have a little dilema..
I bought this dell inspiron 2650 a couple weeks ago. It came with 256MB ram. 128MB onboard, and 128mb in the ram slot.
Now, the laptop is able to have up to 512MB ram, and I see a lot of them on ebay selling with 512MB ram, but I have no idea how they get it up to 512MB.
Here are the memory specs for the system... There is only one sodimm socket, and then it says that is only takes 128 or 256 modular chips. So with a 256MB chip, and the 128 onboard, thats only 384. How can I get 512? Thanks for any help!
Memory:
Inspiron 2650
DDR200 3.3V DDR
Memory module connector
one user-accessible SODIMM sockets
Memory module capacities
128 and 256 MB
Standard memory
128 MB
Maximum memory
512 MB
Zim Hosein
Super Moderator | Elite Member
65,526
410
128MB's of onboard RAM? Are you sure jimrawr?
jimrawr
888
im not positive, but i mean it says right there its only got one sodimm socket, and when i opened it up i only saw one...
Zim Hosein
65,526
410
jimrawr, do you have the Dell webpage you are reading from?
jimrawr
888
I dont, that was sent to me in an email... I can paste all of the system information if it helps
Nohr
7,302
32
101
www.flickr.com
The Crucial site also says 512MB max, and mentions that it has 2 banks. Don't know if they're both user accessible though..
Standard memory: 128 or 256MB non-removable
Perhaps you have 256MB onboard like someone mentioned.
jimrawr
888
I only have 128 onboard, i know that for a fact.. and a 128MB chip
I dont know how to get to 512 :(
Nohr
7,302
32
101
www.flickr.com
Maybe you're stuck with 384MB as a max then, unless there's some way to remove the 128MB stick..
jimrawr
888
Yeah thats what im thinking... but everywhere I look they say max 512.. even in the owners manual.. beh
dethman
10,263
i would assume if you put a 512 stick in, the 128 onboard would be disabled. but i could just be talking out of my ass.
Zim Hosein
65,526
410
In the event we can't help you try posting your issue here: http://delltalk.us.dell.com/supportforums?category.id=inspiron :)
jimrawr
888
Thanks, I posted there too
jimrawr
888
I found the answer... I can change the 128onboard memory, its under the EMI shield under the keyboard
Zim Hosein
65,526
410
jimrawr, out of curiosity, where did you find the answer? :confused:
jimrawr
888
from the dell forums, thanks to whoever posted that
