Laptop power cords
they aren't normally different sizes, but they may supply different current to the laptop, as a rule they aren't interchangeable, but rules were meant to be bent a little bit, if you check the specs on each of the adapters (it will say on the sticker on top of the plug) and they match, go for it.
There are two ends to be concerned about. The end that goes into the power brick. If that fits - cool! The other end is more critical because laptops have difference diameter and depth of pin plugs. Targus has a kit that has adapters that fit all - for their airline power kit. Get one of those and you can solve the problem.
