I need the help of the collective braintrust here. This has me perplexed.
New Dell XPS 15 laptop. Out of the box working perfectly fine. Connected immediately to the wireless router, (Netgear WNDR 3700), and all was well.
I connected via a Cat5 cable the other night so I could transfer files from the old desktop I'll be junking. The desktop is connected to the router via Cat5. (Also have a second laptop on the network and the connection hasn't been affected by this problem at all.)
The problem is this: after transferring my files to the laptop I shut it down and disconnected the cable. When I turned the laptop back on a little later it would connect to the internet intermittently. Even when it did the connection was like molasses. Tried everything and every suggestion to fix the problem. Reinstalled the drivers, reset the modem and the router, uninstalled this and installed that. Finally, after nothing cured the issue, last night I formatted the drive and did a fresh install of Windows 7 Pro. Once I did that the connection was perfect again. Not knowing what I seem to know now I wired the laptop into the router and transferred my data. When it was finished I once again shut it off, unplugged the Cat5, and went on with things. Came back two hours later, turned the laptop back on, and once again I am unable to connect to the internet. Identical symptoms and the common cause seems to be wiring the laptop into the router.
What on earth is going on? Thank you for any help!
