homestarmy
I fixed some issues on my brother's laptop, but I can't seem to get the hibernate option to show. It is an HP Pavilion DV series.
Hibernate is checked under power options. I unchecked it, restarted, rechecked, restarted, still no option 🙁.
Also, when I check the battery, it gives a percentage, but no time estimate. My Toshiba did this by default (as do all other laptops that I use).
It runs WinXP Pro, fully legit, etc, came preloaded.
Additionally, Windows Update fails when trying to install KB898461. I restart and same problem - Failed Update.
