is it possible i say yes i am going to try to liquid cool my asus g72gx i found upon taking it all the way apart that there is enough room in the back for two quick connect fittings inserted in rubber garments i will use copper plate and tubing to make hard drive blocks and North Bridge Block the GPU Block is already copper plate i will clean it up and reform copper tubing circuit for it and on the back of the GPU i will make a bllock for the GPU Ram as for the Memory i will make spreaders out of copper with tubes in the ends and direct those into spacially designed pre sinks where the factory fan will pre cool the individual circuits before they are collected into the main external unit where the controller pump radiator and resevoir wwill be located. how does this sound i think ill market it when i get done if you have any ideas just type?😱
