geecee
I have an extremely outdated P3-500 ultralight laptop but I'm starting to find that it's overwhelmed by some of the things I've been using it for (i.e. Visual Studio 2005 - VB & learning Visual C#). OTOH, I have a fairly new work laptop (Dell Latitude 610 P-M 1.86ghz, 1GB RAM). The only problem with the work laptop is that I do not have admin privileges on it and I can't really install any personal use stuff on it.
So, my thinking is this. I can swap out my work laptop's HD for an old laptop HD I currently have in an external USB case. I can then install a separate copy of XP on there and be able to use the work laptop for my own personal use. Whenever I actually need it for work, it's a quick two minute swap of HDs. On top of that, I also don't need to buy another copy of XP, as I have the original disks that came with the Dell and I can just use the cd key on the sticker on the system, since the PC guys from work wipe every PC that comes from Dell and use a preconfigured install build of XP and other standard apps that have nothing to do with anything that originally came with the machine.
An even further bonus is that I can now install Dungeon Siege 2 on the Dell lappy and play it there! (I never even bothered trying to run it on the old P3).
Does this all make sense or is there something (technical, legal or o/w) that I'm missing? TIA.
EDIT: grammar
EDIT: grammar
