laptop hard drive: 5400 rpm vs 7200 rpm
CletusTheDwarf
219
Right now I have a 60gb 7200 hard drive in my laptop and i need more space. I'm finding lots of great deals on bigger hard drives, but they are 5400rpm drives. Will i see a noticeable slowdown from switching to a bigger, slower hard drive?
andrei3333
449
yes you will, i noticed a difference in my bf's laptop...but unless you are doing more than surfing the web and typing essays you should not worry about it
CletusTheDwarf
219
Do you know any online studies that can show a good direct real-world comparison between drives of the two speeds?
alkemyst
83,769
19
There are tons of benchmarks out there. Usually the 5400 is a good compromise of 4600 vs 7200rpms in terms of battery life vs performance.
If you are always on power and demand the best performance 7200 is usually where it's at. There are a few 5400 rpm drives that perform as well as 7200's. I think it was a Scorpio I bought my wife...may have been momentus. It was IDE/5400RPM. Thing is quiet and was night and day from her 30gb 4600RPM drive.
LOUISSSSS
8,770
54
yes, if u went from 7200 to 5400, u will see a big slowdown in overall system speed. stay with a 7200..
