Is this a Sata drive or is it an IDE? You might have to check your jumpers if it's an IDE and if it's a sata if your board doesn't support sata 3.0 you may have to put a jumper on the drive to get it to 1.5.
Other then that, might want to check to see if you can use another cable.
Remember - this is a laptop. 2.5-in drives are defaulted to Master - jumpers are not commonly available. The HDDs are usually in a drive caddy or tray. What brand of laptop are we talking about here?
