Corporate Thug
- Apr 17, 2003
- 37,622
- 0
- 76
Originally posted by: alexruiz
Second the eMachines......
By the way, I am sure that the person who said that that nothing in the $1400 range can "even remotely compete" with a *ell 9100" has benchmarks to prove it, as "remotely" is quite daring....
ummm, the emachines has a 9600 mobile the 9100 has a 9700 mobile, it doesnt take benchmarks to figure out which is the faster VPU...
Exactly, it should be faster... but if you think "it can't even remotely compete" then you need to check your grammar. The only difference is clockspeed in the GPU. How much? Numbers needed.
You keep insisting on "easily will outperform", well, bring the numbers. Obviously, to say that "it can't even remotely compete" is very broad and general, let's make it broad and general.
The asseveration of "slightly faster CPU" is wrong also.. it is quite faster. You forget that the P4 needs low latency RAM to perform the best, and that is not available in SODIMMs.
if you look at Anands benchmarks, the 9700 is about 25% or more faster than the 9600 pro mobile LET ALONE A PLAIN OLD 9600 @1280*1024 or when AA and AF is involved. I consider that a pretty big performance gap
btw, AMD chips are more dependent on low latency ram, not Intel
edit: lets assume a 9600 pro = same performace as 9600 to compensate for the difference in the CPUs
In Aquamark 3: 1280*1024 4x AA/8X AF = 9700 is ~25% better
In COD with NO AA OR AF: 9700 ~17% faster
in HALO 1280*1024: 9700 is ~32% faster
Jedi Academy 1280*1024 8xAF: 9700 is 24% faster
Knights of the old republic 1280*768 4xaa/8xaf: 9700 is 17% faster
NHL 2004 1280*1024 4xaa/8xaf: 9700 is 27% faster
Prince of Persia 1280*768: 9700 is 27% faster
splinter cell: many scenarios tested, 28-30% lead for the 9700
frozen throne 1280*1024: 9700 leads by 14%
wolfenstein ET 1280*1024: 9700 34% faster
are those numbers convincing enough? i didnt want to take the time to do it in the first place because i assumed you guys would just check it out in anands review.
I dont know about you but it seems to me that the 9700 is far better than the 9600 pro let alone the 9600 non pro mobile. btw, since the 9100 is only 1299.99, you can use the difference is proce to upgrade to a 3.0C instead of a 2.8C in which the processors would be very similar in perfromance and the gap between the 9700 and the 9600 would be evn more apparent than the gap between the 9700 and the 9600 pro
if you check out this
review, you will notice that the performance difference between a 3.0C and a 3000+ mobile isnt very much at all, esp at high resolutions, where the 3.0C whens by narrow margins at time and the A64 3000+ wins at times by narrow margins. therefore, for the same price (assuming you upgrade to a 3.0C), the 9100 will be about 30-35% faster when using 1280*1024 or AF/AA than the emachines since the 9700 is about 25% faster than the 9600 pro mobile
I think i have proven that the 9100 is superior to the emachines.
