I'm helping a friend looking for a 70x10mm laptop fan replacement. I tried looking for it but it seems it's a irregular dimension and havent had any luck finding it. Any idea?
if its hp : go to hp parts direct
if its ibm : go to ibm/support search by computer type and then google part
if its dell : search dell.com/support and then google part
if its compaq : see hp.
