I bought a used laptop (HP DV9009US) from a guy and I find it drains the battery when it is just sitting there, not plugged in. Is this normal??It arrived with the battery completley drained, so the first thing I did was charge it up and see how long it ran and the battery lasted 2 hours before the 10% warning light came on, which I thought was pretty good for a 17" screen and a Turion 52.
So I left it sit unplugged overnight and on powering it up it showed 96% charge remaining. That was 8 hrs of sitting unplugged so i shut it down and let it sit another 16 hours (24 hr total) and when I fired it up it only had 91% of a full charge.
So I downloaded the battery check tool from HP and tested the battery. It showed the battery as having 97% of it's capacity and being in good operating condition. I fully recharged the battery took it out of the machine and let it sit for 24 hours, put it in the machine, powered it up and it showed a 97% charge. I recharged it to 100% and took the battery out of the machine and let it sit for 5 or 6 days, put it in the machine, fired it up and it still showed a 96% charge, so it's not the battery.
Anybody have any ideas as to what could be causing the battery drain?
Should I complain to the person I bought it from? He said everything on the conmputer was 100%, but when I told him about the battery drain he said they noticed that too. Also, the quick launch buttons don't work. All they do is turn the computer on when it is off and if it's on, the volume slider keys work and I can get the DVD button to open up the DVD player software. Like I said though, those are options I don't really care about, I'm more worried if I have a laptop that's got something seriously wrong with it and may die before it's time.
TIA
I like the computer but am worried about what the problem is. If it's not a serious problem I can live with it since I bought it for my wife and it will just sit on her desk 99% of the time and won't get used much.
TIA
