frozentundra123456
Hi all, hope someone can help with this problem with my wife's laptop.
While she was using it, the entire screen developed a sort of translucent horizontal line pattern across it. You could see the webpage below the pattern. It was sort of like looking through a set of venetian blinds or something. In addition to that, the computer was totally locked up. Even holding down the power button would not turn it off.
Finally, I took the battery out and put it back in and that solved the problem at least so far. The computer booted normally and the display was then OK.
So my question is, What happened, and is this a symptom that the laptop may totally fail soon?
BTW, forgot to give specs. It is a 4 year old toshiba with some sort of athlon processor and integrated (motherboard?) graphics. It does run hot, even with a cooling pad. Is it possible that it just overheated?
