Laptop CPU fan stops working after POST : (
anton
Banned
Sep 15, 2000
746
Hello,
I have this problem, when I turn on my laptop , CPU Fan (only fan in whole system) works fine , but after POST (maybe a little later, actually when LILO starts ) it just stops working ; ( ... and you know what this can do to the cpu ; ( ... I checked everything in the BIOS , didn't find a thing ... and it wasn't like this ... why is that ? : (
thanks,
bye.
Eug
24,154
1,803
Fan only comes on when needed. Mine is off when idling. If I do any real work the fan comes on quite quickly.
anton
Banned
Sep 15, 2000
746
I already burned one cpu in there and I don't think that fan works (comes on) properly ... b/c recently I almost burned another cpu ... so is there any way to make it work whole time ?
bacillus
14,517
the fan doesn't stay on all the time. it usually comes on when the battery is being charged with the computer on.
I suggest you try this if you want constant fan cooling for your laptop!
anton
Banned
Sep 15, 2000
746
bacillus : thanks, but I already have that , and my laptop almost burned second time with IT in it ; (
bacillus
14,517
<< and my laptop almost burned second time with IT in it ; ( >>
ouch!
sorry to hear that man but hope you get something sorted! :eek:
corkyg
Elite Member | Peripherals
27,370
240
Eug has it right . . . I am on my third laptop (now 750 MHz) and as long as you have an Intel mobile CPU, the fan really comes on infrequently. There are some cheaper alternatives out there that use regular CPU chips and they run constantly. There's more bitching about the fan running than not running.
A lot depends on your ambient room temp also. Bottom line is, most laptop fans run only when needed. Need depends on sveral factors. To have them run all the time is a huge battery drain. Smart money sticks to only Intel mobile processors in laptops.
anton
Banned
Sep 15, 2000
746
well , I have Intel Mobile CPU too , but I don't feel very good leaving it like this ; ( ...
