Laptop cooling pads
KarthVader
24
Been looking for one for 3 months, but I can't find any cooling pads that will fit my widescreen laptop. Please help oh wise ATGHers.
pkme2
3,896
I've a Yate Loon cooling pad for my Inspiron and its kept its cool.
w00t
5,545
that's the same size as a macbook pro i'd try to look at the apple store accessories might be able to find something.
Aikouka
30,383
912
I just bought one from Circuit City where I got my laptop and it works fine. Note that my laptop is also a 15.4" widescreen.
Raduque
13,140
138
The fan on my dad's laptop just died, so it overheats. Would one of these let him use it longer then a couple hours? Or should I just tell him to order the replacement fan from HP?
benplaut
229
i recommend you stop using it until you get a new fan... you could cause some damage
imported_goku
7,613
You know you bought a ****** laptop when it needs a separate device alltogether (from what is included) to cool it's self from overheating... The concept of cooling pads is sad and pathetic.
