Laptop Connection Problems
mjuergens
I?m out of ideas now. When using my laptop the connection seems to drop every half hour or so. I have this problem in my dorm room using the Ethernet and Wifi. My roommate has no problems. I used Wifi first and started noticing this happening, I then switched to Ethernet and the same thing was happening. Now that I?m home on winter break I notice the same thing is happening. Yet again, the other computers on the network are fine. Therefore, I don?t think it?s a router issue. Could this be some setting in windows that I?m not aware of? Any help would be appreciated.
Just for reference, I?m using the following network adapters:
Realtek RTL8139/810x Ethernet
Atheros AR5001x+ Wireless
